Loss of power under load
- Replies 19
- Views 3.1k
Mopar1973Man 8 posts
Jeff e. 8 posts
dripley 3 posts
I'm going to assume you have a Timbo's there is no voltage to set it about the angle. Lift pump is weak. Fuel system too restrictive. You should have only a 2 to 3 PSI drop not a 7 PSI d
The only thing I can add is free revving in neutral is not a true measure of fuel pressure. Other than idle you need to measure under load on the highway. Chances are you are much lower that you think
Check all your OBDII pins. I've had a Smarty Touch behave the same way and found one of the SCI bus pin pushed out the back. You'll have to push the plug out of the metal tab on the dash and verify al
Newby here. Sorry if I posted in the wrong area. Just got this truck so the super chip is going in the trash.
Ok I have full gauges.
New vp new lp new apps.
I have no white tag to set volts to first off. So how do I know what to set it to?
Second it revs like a monster in neutral with 13psi. Wot it's at 11psi idol its 18psi.
Pulls hard till about 20psi of boost or 2200 rpm.
Then sometimes it does it at 10psi and 1400rpm. Sounds great till then. If you ease in to it it wont change anything. And I can't get the chip to connect to ecm. I get a code but only after I run the truck.shut it off code goes away.
