2006 48RE weak reverse
- Replies 12
- Views 7.3k
deereman01 5 posts
Dynamic 3 posts
AH64ID 2 posts
RobD 1 post
2006 Ram CTD 4x4 with 48RE, 167,xxx miles. Brought it home with a blown #4 injector line. I know it would pull on the gooseneck with a lot of throttle, and reverse seemed alright, but didn't drive it much. Fixed the fuel line, and on to the trans. Park would hang so bad we thought we would break the column shifter. Previous owner installed Derale pan. Dropped pan, found glittery fluid, pulled valve body, installed Georend bullet detent kit. Reinstalled valve body, and filled with new ATF4, and there's a weak reverse or 1st with engine braking. Put a transducer on the rear servo port, and I'm seeing 180-190 in reverse at 1500 rpm, but the truck still won't pull in 4 low. 1st has no engine braking, pressure ranges from 65 at idle to 70-72 at 1800 rpm. Removed the TTVA, ran the throttle lever around by hand, and pressures go up to 285-290.
Drove it around the block, and I have this shudder in forward at really low rpms, and the same shudder in reverse, and it won't back up a slight incline.
I turned in the screw under the throttle valve a few rounds, because as my wife would step on the throttle, it wouldn't push the throttle valve in all the way. Pressures came up some, but it still doesn't feel right.
Didn't take anything else on the valve body apart except the manual valve to put in the bullet detent, so I'm stumped here. I also made a mistake and didn't gauge the pressures before, since it was only a park detent issue. Anyone have some really good ideas, or is it toast?
