Is there any oil that flows through the head under pressure? Doesnt ALL the oil in the head come through the push rods?
  • Replies 2
  • Views 961
  • Oil through the push rods are with hydraulic lifters like in GM engines. Below shows the oil flow in the Cummins 5.9L from the FSM.
There are oil ports into the bottom of each set of rockers. As far as I know, there is no oil port in the push rod at all. Never really looked but I'm pretty sure there isn't.
