HELP... 24 Valve rough idle when hot
- Replies 10
- Views 2.5k
Mopar1973Man 4 posts
SSIRMAN 4 posts
Dieselfuture 1 post
cumminsdog 1 post
Popular Days
After you make sure you have no excessive AC noise and do ground mod and still have problems it could be your PSG on vp44 or ecm from being damaged by AC current. When you not touching go pedal ECM is
check for air in your fuel system.
Thanks mopar1973man, i replaced the alternator and did the ground wire mod. Been driving it for a few days with no problems so far
Okay so i bought this truck and drove it with no problems except for having to rebuild the weak auto trans
, but i was driving it for about 15 minutes and got it good and hot then i stopped at a store and when i came back outside to leave, when i started my truck back up the engine started revving uncontrollably up and down like i was stomping on the pedal really fast on and off. I turned it off and caught a ride from somebody else and when i came back later, it started up just fine and i drove it home. Ever since, this has happened maybe 4 times and once it happened while i was driving. I got to a red light and the truck shut off, when i tried to start it back up same thing happened. Ive always had a weird idle where it kind of sound like an intermittent miss, but now it seems more severe. Even when i rev the engine and hold it at a higher rpm i can still feel it missing intermittently. I checked the codes and i got P1690 and P0341. I have replaced the cam sensor, checked all the wiring between the TPS and ECM and the CPS and ECM. Since this started i have tried multiple repairs like replace the lift pump and injectors because of info found on other forums. I sure hope it isnt the VP44 or the cam reluctor wheel. What do y'all think? Any help would be appreciated
Edited by SSIRMAN
