99 24v p0341 won’t clear
I’ve changed the cam sensor and the crank sensor but the code keeps coming up, I have also chased down all the grounds and cleaned them along with connectors.. I have 5v to the orange at every connector and or plug I’m at a loss for words right now
  • Replies 4
  • Views 2.2k
  • 4 weeks later...
I replaced the ecm and pcm everything was fine for two weeks now im right back to the p0341 and no tach. I’ve replaced both crank and cam sensors and still the same problem truck is causing me a headache
start probing the wiring between the ecm and the sensor and verify nothing is busted / brittle / or bad connection.
Possible Causes
  • DTC Equal To Freeze Frame
  • High Resistance In Ground Circuit
  • CMP Sensor Signal Circuit High Resistance
  • CMP Sensor Signal Shorted To Ground
  • 5-volt Supply Circuit High Resistance
  • CMP Sensor 5-volt Supply Circuit Shorted To Ground
  • Intermittent Wiring Harness
  • ECM
