Exhaust Brake Minimum Setup 2002 Cummins w/ Manual Trans
- Replies 27
- Views 9.1k
Mopar1973Man 4 posts
015point9 4 posts
Hypertufa 4 posts
2000Ram2500 4 posts
Seeking feedback, ideas,
To install an exhaust brake (EB) with a non stardard method to control the EB.
How?, leverage some functionality by adding micro switches, relay(s), tapping into the vehicle control modules.
This is not the preferred setup and will require the operator or system design to replace the functionality of an electronic control box.
Why? I have the brake itself, don’t have the expensive electronics.
Thanks in advance, First Post Ever,..
Application:
2002 Dodge Ram 5.9 H.O. Cummins, 6 Speed Manual Trans.
i figure a switch and string of micro switches that will turn the eb on/off could be used inline to the activation relay for the vacuum control valve.
Proposed Setup
Main Switch - 2 Speed Axel Switch on Transmission Shifter
pull to turn on, provides a ground to a micro switch string, somewhere on the throttle and clutch.
The micro switch string will interrupt a Bosch relay, controls the vacuum solenoid for the EB.
when you push on the throttle or clutch, the vacuum solenoid for the EB will deactivate dumping the vacuum in the EB.
Ideas, thoughts, what would you do differently?
Edited by Hypertufa
