Wastegate spring?
Happened to stumble across this video on youtube over the weekend. Was wondering what everyones thoughts were. Looks pretty simple just not sure if there are any cons to it. Only thing that comes to mind right away is how does he plug the existing port for the wastegate?
  • Replies 26
  • Views 16.5k
  • If you guys are using single turbo's, it would need a heavier spring than what's used on a compound turbo application.   Judging by memory, go with a 60 to 100 thou coil wire thickness, and
  • I couldn't have said it better.   I'd put a locknut on there too, once I got it adjusted to where I wanted.
  • The 20* elbow is the factory one. Some aftermarket ones are adjustable and some are preset. The one that come with my EZ is a preset one. Max boost with it is 32 psi. I plugged mine and it still has 3
2000Ram2500 - if your existing canister holds boost pressures, I would simply add an adjustable turnbuckle to the existing Holset actuator.
Along with fuel limiting to your desired unloaded EGT, this would be the easiest, most cost efficient option.
It's not leaking that I know of but I'm sure being it's the factory actuator its weakened over time with heat helping it. Not that a spring from wherever wont do the same over time I just feel like a turn buckle wont necessarily help my case because it's still the same spring inside the actuator which means it's not gonna take a whole lot more to pull it past it's new tighter position. Maybe I'm wrong but I'm sold on the ease of having just a nut to tighten as opposed to having to get in there and tighten a turn buckle.
  • 4 weeks later...
My lift pump went out like a week before your post @Marcus2000monster I finally got one ordered up and it came in friday. Hopefully i'll get it installed this week before the rain/snow is supposed to come back this weekend. Then i can focus on other things and hopefully come up with a parts list and some info
