HIGH BEAM
Hey guys,
I lost my high beam function on the passenger side of my truck.  I know it's not the bulb because I already replaced it with a new one.
What color wires should I be tracing to repair this issue or what might the problem be?  The high beam function works perfectly on the driver's side.
Thanks
  • Replies 19
  • Views 3k
    +12V -> Fuse -> Bulb <- Dimmer Switch <- Headlight Switch <- GND at driver side kick panel.
4 hours ago, Marcus2000monster said:
Might be the multi function switch.
The high beam on the driver's side works
From the splice up to the socket would be my guess. Could very well be the headlight socket too. I've seen them melt over the years.
Can I splice from the driver's side high wire to the passenger side high beam wire and it works?  If so, what color is the wire?
I would not suggest hacking wiring right away. First test if you got the ground signal there first. Double check the headlight socket for melting or bad contacts first. Really suck to hack up the wiring and that wasn't the problem.
Would having "low beam" be an indication that ground is in tact?
Edited by Toughspot
No.
There is two different grounds the hi beam leg and the lo beam leg from the dimmer switch. The ground leaves there heads to the headlight switch and ties in at the drive side kick panel inside the cab. The fact that the headlights come on just proves there is ground. But the ground for the hi beam leg might be damaged from the splice forward or the actual headlight socket.
Image result for 9004 headlight melted socket
No.
High beam works on the driver's side.  Does each headlight have its own high beam ground?
By the way I checked the socket out yesterday when I changes the bulb and it was good.
Edited by Toughspot
Yes, until it reaches the S105 splice.
The wiring is backwards on our trucks the common on the bulb is +12V the hi beam and low beam leg are controlled by grounds.
Okay... I saw a ground that's not connected and I left it off.  Wasn't sure what it was for, but it looked like it went to a component like box and all the other wires from the lights also join.  I'll connect it this evening when I get home.
Headlight ground is in the driver side kick panel inside the cab.
Okay
  • 3 weeks later...
Hey guys,
I found what what the problem is.
Back in the day I installed a britebox that would allow my fogs to stay on with high beam.  There are some loose wires.  I need the installation manual to sort this out because there are some splices in this circuit.
Any assistance would be greatly appreciated
You might be able to get the install manual offmtheir website. I know can get install manuals from most products without buying the product. But if yours is old things might have changed.
I found the install manual.
Thanks bud
thebritebox.pdf
UPDATE:
Hey guys I found the problem.  Apparently my high beam wire (red wire) was cut.  Once I connected it along with my thebritebox everything worked fine.
Thanks for all your help
