2001 bucking and smoking
Have a 2001 dodge nv4500 I’m having issues once the gauge starts to move and truck warms up I’m having a cuttting out issue around 18-2200 rpm it’ll cut out like it’s banging off the rev limiter have some whiteish blue smoke and you can floor it and it goes away.
Ive replaced the. Injection pump,lift pump with a air dog 150,  injectors, turbo, cam sensor. Tpps, map sensor, IAT sensor, coolaint temp sensor,
fuel lresure is 18 at idle 14 at WOT
Funny thing is if you drive the truck like a jack *** it doesn’t mess up but if you drive it normal it messes up every time.
Ecm???
Edited by Hsmtrans
  • Replies 9
  • Views 1.6k
AC noise? Have you tested for excessive AC noise from the alternator?
Bad master ground for the ECM (passenger side cable)?
Most likely you're drifting slowly into this RPM band and the AC noise comes on fouling the tach signal with a harmonic that the ECM thinks it's over-revving so it cuts fuel. Then if you stand on the throttle then you pass that band of harmonic and the ECM pulls through.
Dumb question, best way to check ac noice?
Edited by Hsmtrans
DVM meter...
 DVM has to have AC scale for 2 volts or LESS. The DVM need to be able to measure more than just 60 Hz AC frequency like house power. I know O-scope is the best way but most people don't have the money for a good one. Like myself, I use a Fluke 75 DVM and it auto-scaling and reads on just about any frequency still.
After you verify that then we'll talk about ground wires and fixing them.
22 minutes ago, Mopar1973Man said:
DVM meter...
Ok I’ll have to grab a multimeter only have a power probe
I can’t seem to find what I need. Can you lead me in the direction of where I can get what i need? Part store Home Depot etc the one they have here at the shop doesn’t seem to go low enough at all
this is what they have https://hc-cargo.com/files/billeder/ecom/products/fg_annex/DK055196.pdf
I don’t think it’s the alternator I unplugged it and pulled the fuse and no change @Mopar1973Man
Edited by Hsmtrans
I believe the power probe 4 will do A/C and a lot of other things I just got a used one and sold the III power probe.
Do you have any type of programmer?
