Fuel and Boost Pressure, what is good?
- Replies 5
- Views 2.7k
Mopar1973Man 2 posts
notlimah 2 posts
unioncreek 1 post
The truck is basically stock, except I have installed a Heath wastegate controller (spring type). Truck has 270K on it.
I finally installed fuel and boost pressure gauges in my 96. When cold fuel pressure is 30 pounds at idle, 38 pounds at 2000 rpm's. At operating temp idle pressure is 22, at 2000 rpm's 32 - 34. Is this with in specs?
My boost running down the road with my my car trailer on hauling a ton is 6 - 8 pounds. Maximum boost that I can get is 28 pounds. Again is this good or could it be better?
Bob
