- Replies 11
- Views 2.1k
69superbee440 6 posts
Mopar1973Man 4 posts
Dieselfuture 1 post
Popular Days
ABS module. PCM doesn't control speed data. The only thing PCM is doing is starting the CCD network. The PCM gets the CCD network going and ABS module calls out on the network its speed da
I suppose it would be possible that my abs module is faulty and triggering random ABS brake light on and not the wheel bearing itself or a front sensor
Been trying to solve my intermittent speedometer for awhile now. It is possessed acts up under all different conditions speedometer will read pretty close to exactly double! Sometimes will do it frequently between drives other times can go a thousand miles without acting up. Shut the truck off and restart it’s all good. Checked wiring I found a repair on vss wiring but appears to be good. Replaced vss and inspected tone ring on diff. Speed on my edge matches speedometer when it acts up. Scanned and got code 74, 67, and 65. Should also add that truck has a 4w abs module but front hubs without sensor. I “fixed” this by tying front sensor wires into rear. Was acting up before I modified wiring (unless my memory is slipping which is possible) . I’m thinking ecm issue where it reads exactly double. Open to hear everyone’s thoughts. I’m sure there is lots that I checked that I’m not posting. What makes it worse is when it happens can’t do highway speeds because truck hits governor.
Edited by 69superbee440
