Possible VP44 trouble!!!
- Replies 31
- Views 4.5k
JamesL8816 15 posts
Me78569 9 posts
Mopar1973Man 3 posts
Dieselfuture 2 posts
Drive it like it doesn't owe you anything. Vehicles can sense weakness and will take advantage of it..... similar to a horse, must of been passed down from cars of the early 1900's form horses.
Disconnect the VP44 wiring harness connector completely. Connect pin 6 on the VP44 to battery ground. Connect pin 7 on the VP44 to battery positive. A diagram of the sockets on the VP4
Alright so after about 10 hours total, the fuel tank is clean, lines cleaned with no leaks, new filter, new vp44 and help from a number of people with ways to test, the ol blue b**** is back on the ro
So I have an issue and I'm hoping it's not my injection pump. I've check all my fuel lines for leaks and everything is working as it should, no air all the way from the tank to the return line off the side of the vp44. Truck will not crank. Went to bleed lines 1 through 5 at the head and only getting fuel to lines 1 and 4.
