- Replies 5
- Views 2.3k
Rotax3006 2 posts
CUMMINSDIESELPWR 1 post
trreed 1 post
Tractorman 1 post
Popular Days
You can remove the vacuum pump with the VP out. Both the VP and the vacuum pump run off of the van gear, and the VP gear will stay in place.
If you weld that bracket, it is crucial that it is in exactly the correct position or undue stress can be placed on the VP44 when it is tightened down. My truck is a pickup, not
Hi guys
Thanks for all the responses on my last post. It’s nice to find a page that has knowledge as well as courtesy. So I pulled my VP44 and found a broken rear bracket. Looks like I need to remove and replace/weld. My question is can I remove the vacuum pump with the injection pump removed or will the pump gear fall down. Looks like both run off the crank from what I can see. Also looks like a good time to rebuild that oily mess. Thanks and Merry Christmas
Bill
