- Replies 7
- Views 4.7k
Miles209 3 posts
Mopar1973Man 2 posts
Tractorman 2 posts
I do my best to try and figure what I can without asking others for help but I'm stumped on this one, trucks been starting fine, went to the store, came back truck wont start, figured just a starter, a few years old. Replaced it, still no start. Started chasing wires power to the starter but nothing to solenoid 5v wire with key cycled to the start position. Pulled the relay. I have no constant power to pin 30. Dont know if there should or shouldn't be, all the other relays have power on 30. If I jump power from pin 86 to 87 and crank the key it fires right up, the list of things I have tried goes as followed. Jumped the clutch pedal safety switch. Checked every last fuse and relay, tried three brand new relays in the starter relay spot, all relays click. The only thing I'm not sure about is if the ignition switch supplies power to pin 30 in the relay, or if the main fuse going into the panel supplies power to pin 30, any input would be greatly appreciated
