- Replies 30
- Views 4.7k
2001white 12 posts
Mopar1973Man 9 posts
kzimmer 5 posts
Dieselfuture 2 posts
alright guess my old edge can watch the TPS we are at 0 at idle like it should be. Trucks running great for the last 3 days. Idle RPM does fall to 750rpm according to my edge tuner when comming to a s
You need to do it after you drive it so grid heaters aren't cycling, or unhook them from battery. Even if truck is warm they will still be cycling, so best way is to drive it above 25mph I believe an
Agreed. But his meter doesn't show 0.57 volts, it shows 0.57 mv, or .00057 volts. Low quality meter or not, it's on the mV scale. Will likely be more accurate than a meter that's sitting o
Had this issue once before for a split second but truck jumped back to having power. Tonight though no luck.Was driving home and RPMs were stuck at 2000rpm and 20mph.
If i pushed the pedal all the way down still same rpms just held at 2k. Truck is an 01 auto and p0720 is the only code to show. Fuel pressure is good. Truck drives great tell I get to 20mph lol.
Edited by 2001white
