Leaf springs/ replacement broke
Last fall I broke a leaf spring mid pack in the spring pack on the drivers side.  That spring pack according to the manual needs the tank dropped ugh.  So I used a heavy duty rubber strap to hold it together and it has worked fine so far.  Now the passenger side broke(I would take a dirt road over how bad these paved roads are) unfortunately that one was the last spring before overload and that pack is less than 5 years old(replaced this side once already). Any suggestions to temporarily fix? Or....
Can someone please recommend a quality source for a replacement set and any suggestions for ease of removing drivers side spring would be appreciated thanks.
  • Replies 6
  • Views 2k
  • Benz Spring in Portland, Oregon has a great reputation for making custom springs. You could give them a call since they know what they could do for you and have them shipped. Their pricing wasn't bad
  • WiscoRedkneck
    WiscoRedkneck
    Haha us used to salty suck of the salt belt has come up with some creative home remedies over the years.  Such as clearance aisle synthetic motor oil of any flavor into a garden sprayer and cover ever
Benz Spring in Portland, Oregon has a great reputation for making custom springs. You could give them a call since they know what they could do for you and have them shipped. Their pricing wasn't bad the last time I dealt with them on my old first gen. That was quite a while ago though as I'm old fart now according to the Millenials.
I have broken one spring in a stack on 4 different trucks and just went to a custom spring place and ordered just the broken one and restacked them. Some places will know what you need right off hand but others needed the spring in hand before they can help you.
look at summit or the like for a superlift soft ride 4" lift rear leaf...this will allow for removal of the rear block with very minimal height change...and controls axle wrap much better.
Thanks for the information I went to a spring shop here in Wisconsin to replace the passenger side.  That side was done years ago and has now broke again, that spring has maybe 1/3 of the miles on it compared to the drivers side that is now also broke.  Do any of you know how well these options you suggested will hold up?  Mind you this truck has a 60/40 life meaning less than half of the time I am on inprovded or paved roads.  I will have to call Benz and check out superlift
lots has to do with the quality of any coatings applied also...one winter in your area...TOTALLY ruined my chassis and now body. i couldnt wash it enough to get the salt off.
Haha us used to salty suck of the salt belt has come up with some creative home remedies over the years.  Such as clearance aisle synthetic motor oil of any flavor into a garden sprayer and cover every nook and cranny with oil doors fenders wheel arches I mean everything I have no rust on the newer body that has spent 5ish years up hear now with almost 380,000 miles.  That being said you are right it is a constant fight, this spring I'm setting aside 500 per month for four months to repair deer strike damage rock chips and broken bumper plastics along with replacing and repainting the tail gate which is heavily damaged and also a sorta fit certain fit pos.....
Edited by WiscoRedkneck
Most myself included dont what a garden sparkler is darn auto correct
