Brake Bleed Problems....
- Replies 4
- Views 1.7k
Mopar1973Man 2 posts
JAG1 1 post
keithb7 1 post
Popular Days
I've used a mayo jar for years and never used anything else. Bleed my brakes solo for years! Check the frame for rear axle weight valve. If the weight on the rear axle is too
When bleeding the wheel cylinders on the rear you are supposed to start with the right rear then go to the left rear, (you mentioned you started with the left rear) Always bleeding furthest away from
1998.5 24V. Rear wheel ABS. Recent work included: 2 new rear wheel cylinders. New rear shoes. New shoe springs & related hardware and new rear drums. Two rear brake lines were so corroded they snapped off at the nut on wheel cylinders. I made new lines. Mounted everything up. Unfortunately had to go to work, and could not get the new lines on for a day or two so master self drained. All rear shoes and hardware seemed to go on fine, and appears to be functioning properly. Recently I read several posts about bleeding brakes. I filled up master and started with my mity-vac vacuum system at each corner. Attempted to bleed by myself. Little results felt on the pedal. Tried again this morning with a helper and manually bled the system. Helper pumped and held down while cracked lines. I started at the master cylinder lines and bled, then on to the proportion valve line connections. Then the ABS connections. Then left rear, then right rear cylinders. Then front right and finally front left. All the while constantly topping up the master cylinder reservoir. Not allowing any air in the system. Master cylinder is still too low. I have rear end jacked up, re-installed wheels and fired up the truck. Rotated wheels and applied the brakes. I am barely getting enough to stop the rear wheels. There are no leaks. I just can't seem to get enough power through the master to each wheel. Maybe there is more air in there? I've gone through a fair bit of brake fluid and pumping.
Brakes worked fine before I touched them. I went in for a leaking rear seal and went further based on other findings. Front pads are decent. Going back out now to manually adjust the rears. Make sure they are right and try again.
Any tips? Thanks.
Keith
