- Replies 3
- Views 1.7k
Mopar1973Man 1 post
dripley 1 post
01Cummins6spd 1 post
I'm new to the group and still learnin the Quadzilla as well (bought it in Jan of this year) so any help is appreciated. To give you a little history on my issue, I was towing 2 weeks ago and got a dead pedal intermittently then it quit for about a week then came back again. Had a P1689 code but no TPS. I cleaned all my grounds and battery cables along with TPS and VP plugs and then it ran smooth but with absolutely no power at all. I checked codes again and had a TPS code saying low voltage. We graphed the TPS and it was all good. Then ot through a code for the map sensor and that was only changing between 2 voltages so I unhooked the quadzilla and hooked the map up oem and it runs fine. The quad shows rpms yet but I lost tps. Also it doesnt change anything no matter what level its on. Any ideas on where or what to check next? Thanks in advance
