99 Ole Rusty - Cab Rust
- Replies 38
- Views 8k
JD435 13 posts
Timd32 11 posts
Mopar1973Man 5 posts
dripley 3 posts
Well went down to Moyock, NC and picked up a 2000 Dodge 1500 cab, both fenders, hood, front support and passenger door. Started stripping down the cab and have not found any rust yet. W
If I was in that position I would change the cab. They are cheaper then the hassle. http://www.car-part.com/cgi-bin/search.cgi?userSearch=int&userPID=1000&userLocation=
Ram 1500, 2500, 3500 cab, doors, hood, grill, fenders, and interior parts are the same. Suspension, brakes, and drivetrain are a different animal. , I go to the pic-a-part yards, there are
The truck I bought 10 months ago had a lot of frame, cab corner/rocker, front fender rust. The rear fender just starting to blister in the wheel well and the cab floor boards are solid with some light surface rust some spots. That being said I could deal with these rust issues but...
Copied this thread over from Cumminsforum.com since can not upload photos...
https://www.cumminsforum.com/forum/auto-body/2482091-1999-ram-2500-rusted-out-cab.html
I have a broken dash, a leaking heater core and water leak around rear window so removed all of the interior.
Remove the wipers and cowling cover to get a better idea what is going on. Notice on this truck the firewall does not go all the way up to the windshield but there is a large plenum space. The interior cab side of this space the seam sealer coating in the trough has all flaked apart. The space by the driver A pillar has heavy rust from where water was standing. The drains are in the cowling space. Truck was parked outside for three years on a uphill incline so assume this was cause with the water pooled in this location.
Debating course of action - since I will also have to deal with rocker/cab corner replacement on both sides, a cab replacement from a drier southern location may be better option.
Right now leaning to just address the rusted areas and weld in new metal where base metal is thin.
Need suggestion recoating the inside of this plenum space.
Bob G.
Edited by JD435
Add a line
