Looking for Staff Members
Maybe a stupid question but I’m having trouble finding non-conflicting information.
I know the PowerMax is a fuel only box. I am trying to figure out if a box for an 01-02 can work on a 98-00 truck. I know the MAP sensors are different (plug and voltage values). I have read some info saying that unlike EDGE the PowerMax box will work on all years with a MAP adapter harness. Can anyone here confirm or deny this information?
I have tried to contact TST but they are closed until Monday.
  • Replies 4
  • Views 1.5k
Like Me78569 said.^
Yes, it will work from 98.5 - 2002.  Map sensors are different like you mentioned. 98.5 - 2000 is same the map, 2001 has it's own map & 2002 has it's own map also. What are you going to use for your timing?
5 hours ago, jag said:
Like Me78569 said.^
No idea what I would use for timing yet. I just found the TST for sale local to me but the guy doesn’t know how much he wants for it and I wanted to figure out if it would work for me or not before I even bothered offering anything. If it’s not going to be budget enough once I find a timing box too then I will just continue waiting to get a quadzilla.
What are are the best and/or cheapest options for timing?
When I had my setup I ran a TS MVP but it appears they do not make them anymore for our trucks. I should have kept my setup until I got the Quad working. Truck ran a lot better with that setup.
