Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 5
- Views 1.8k
Popular Days
Did This Forum Post Help You?
Show the author some love by liking their post!
I've got an ECM that no longer powers the lift pump on an 02 24v Cummins HO.
I replaced the VP44 and hotwired the aftermarket lift pump (airdog raptor) to test. Manually supplying power to the lift pump and bleeding injectors did the trick, so now I need to wire it in properly.
I read the article on RF noise with aftermarket lift pumps, so I'll modify the harness with a .1 Mfd Orange drop capacitor and modify the pump when I have it out again.
Given that my ECM lift pump circuit is DOA, where should I grab a trigger voltage to engage the lift pump relay?
I am looking at the light green and black wire carrying ignition power at F18 in the first diagram in the engine wiring diagrams post.
Is that the best circuit?
