1998.5+2001=headache
- Replies 8
- Views 3.5k
RyanBelesky 4 posts
Mopar1973Man 2 posts
cumminsdog 1 post
Timd32 1 post
So here’s the project: 1998.5 24v: ECM, PCM, engine harness, pcm harness, engine bay harness, and gauge cluster all 1998.5 from same truck. The cab/ dash harness is a 2001 gasser. My gauges power up fine, shows rpms but nothing else. Gauges appear to pass self test. Codes 920, 921. DOES NOT give me a NO BUS...
I installed my brothers 1999 pcm and no change, took my gauges and pcm to his truck: my pcm works and his gauges work in his truck, my pcm and my gauges work in his truck. His pcm and my gauges work in his truck....
So: I feel that the 2001 dash harness has different wiring than the 1998.5.... also my head lights don’t work properly.
My question now: can I get a couple wiring diagrams of the main grey plug under the dash so I can move the wiring around to make this work or am I better off trying to get a 1999 dash harness and see if it works with my 1998.5 engine bay harness??? Thanks for any input and sorry for a long first post but I wanted to be thorough.
Edited by RyanBelesky
I made mistake
