- Replies 6
- Views 1.5k
CarlAlberts0616 3 posts
JAG1 2 posts
Mopar1973Man 1 post
Popular Days
I figured it out. Was putting out a ton of AC current. Unplugged the alt and so far its normal. We will see about the dead pedal. But its looking good..
You could disconnect the two alternator excitement wires off the back of the alternator and see if symptoms go away. Another much needed upgrade that's helped many in your situation is doi
AC noise you need the W-T ground wire mod. Then for the dead pedal it could be APPS sensor failing check for a P0121, P0122 or P0123 code.
First post! Howdy y'all. I have heard good things about these forums.
Anyway, my truck (see sig) has some weird issues. It runs great, then all of a sudden it will lose throttle, pedal it a little and it will come back. It is also shifting very erratically. 1st sometimes hangs, 2nd to 3rd normally fine, 3rd to OD and lockup it hunts really bad for both.. Going to check alternator for Ac voltage tomorrow and add/clean grounds and some of the normal things. Anything else I should check or do? Has a brand new Industrial Injection VP and Fass lift pump. When the truck runs, she runs good. Fast, strong, shifts GREAT.
Also, no codes thrown! Validated with Snap-On scanner..
All suggestions appreciated, thanks!
Edited by CarlAlberts0616
