Finally upgraded my OBA.
- Replies 7
- Views 2k
Ed ke6bnl 2 posts
Sycostang67 2 posts
Evan 2 posts
015point9 1 post
Popular Days
I am running I think a 540C viair. it finally took a dump, there are rebuild kit that are not expensive and rebuilt it and works great again. I ran a air quick connect to the rear of the truck and it
My makita has more than most air tools I've been around to
I had been running a Vixen air horn setup, consisted of the horn and a little 1.5 gallon tank with a built in compressor. I put a T-fitting on the line so I could use it to air up tires on occasion. That little compressor finally crapped out. The motor still works but the bearing in the connecting rod of the compressor is nothing but dust and ball bearings now. I did a little research and learned about compressor duty cycles and decided to go with a new Viair 450C compressor which has a 100% duty cycle. I also got a new 5 gallon air tank so I woudn't spend as much time waiting for the little one to fill. It's probably a little overkill for my needs but the 450C was only a few dollars more than the lower models. I still need to run a heavier power wire as this unit draws more power than the littler one but I hooked it up temporarily to make sure everything works.
