- Replies 13
- Views 13.9k
Evan 4 posts
01dodge24v5.9 4 posts
Bullet 4 posts
Royal Squire 1 post
Once your tires have started to wear they likely won’t get better
@@Bullet I have new fox 2.0 shock also forgot to mention that. I recommend them btw really improved the handling. @Evan I was kinda afraid all they did was adjust the tone, but I
Run toe at zero castor as positive as itl go. Dont trust tire shops to know what they're doing or seeing on the computer Yes you can adjust castor yourself. The bottom contral arm mou
I have a 01 dodge cummins 4wd, it has synergy steering, BD track bar, EMF ball joints and Redhead steering box.
I recently had it aligned and I'm still getting tire noise and wear(getting choppy) and the truck still wonders back and forth.
I'll attach my alignment specs the shop set everything to. I need some help with what is correct? Because I went from the Y style to the T style steering and I think it not correct now.
