Need help with tune
Im new to this so forgive me if i mess somethin up.. i have an 02 cummins quadzilla adrenaline v2 tuner, 150hp injectors, fleece cheetah 63mm turbo, and an afe bladerunner gt intercooler.. i need help with a tune.. i want it to pull hard.. im not a burn the tires off kina guy i just like that set you back in the seat pull.. right now it smokes real heavy black all the time and the turbos laggy thank you in advance
  • Replies 6
  • Views 1.9k
  • Give our starter tunes a look over   https://mopar1973man.com/forum/185-standard-quadzilla-adrenaline-tunes/     Any of them marked " mid injector" should work for you.  might
  • an extra 2x worth of fueling on a stock injector truck.   canbus only ( no wiretap ) is ~65hp over stock on a stock truck canbus plus wiretap is ~150-180hp over stock on a stock truck
Looking to get adrenaline for my 24 valve do u have to wiretap vp
Edited by Me78569
