- Replies 12
- Views 2.9k
Gregturley 7 posts
Bullet 3 posts
dave110 1 post
IBMobile 1 post
Popular Days
@Bullet Here you go. Amazon-- Volvo relay-MTC VP293 / 1259750 Transmission Overdrive Relay (M46 Blue, Volvo models) $12.60 mini toggle switchs--TEQStone Pre-wired Mini Toggle Switch SPST On
Lock up switches and air pressure gauge. Switch by air is for ZXT.
"System on" light. Tried it this am going to work. Tad bright in the dark but i cant miss it.
@IBMobile Got my lockup switch installed today.
Hit momentary switch and converter locks. Hit it again converter unlocks. Hit brake it unlocks.
I used a toggle switch instead of a dimmer switch. When i flip the toggle it locks without pressing the momentary switch and brakes do not unlock converter.
Only did a short drive to check operation but seems to work fine.
Thanks for the write up.
