Got email! My order for my fuel pressure gauge has been shipped.Ordered a pillar pod to put it in so it will be to my left side on the pillar.I have everything to connect it after I receive it. Will be interesting to see my fuel pressure as I drive.I will keep up on my posting after I get the job done. I will snap a picture and send it after it is in and working.:hyper:
  • Replies 5
  • Views 2k
I've been running my Glow shift Fuel gauge for almost 2 years now and no problems what so ever. Make sure you use a snubber or needle valve set up as Mike often speaks about to control the pulsations to the gauge not to kill it. Glowshift buisness is actually about 30 mins from me.Good Luck,John
I've been running my Glow shift Fuel gauge for almost 2 years now and no problems what so ever. Make sure you use a snubber or needle valve set up as Mike often speaks about to control the pulsations to the gauge not to kill it. Glowshift buisness is actually about 30 mins from me. Good Luck, John
See it works good don't it! :thumbup2:
