Looking for Staff Members
Three cardone units later I'm asking if ANYONE has had good luck with a particular remanufactured hydroboost.  I need one basically immediately.  That said, I already tried rebuilding it just to find it had mechanically failed (scarring on parts I can't get).  I even tried to rebuild the units that failed only to find they all suffered some sort of assembly error and needed hard parts I don't have.
If anyone has had good luck, point me in the right direction.  Thank you in advance. Oh and move this if needed, not sure if powertrain or not.
  • Replies 4
  • Views 1.7k
What is failing ? Could you get another changed under warranty and rebuild it before the failure.
It's got to be an assembly defect or seal defect of some kind.  I ended up ordering a NOS mopar parts boxed unit on ebay, convinced him to ship it overnight to the detriment of my credit card and voila problem solved.  Now just to replace all the transmission lines and maybe just maybe the leaks will stop.
