Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
Hi all, I’m having an issue with my 1997 dodge 2500 4x4 Cummins. Issue started after I let the truck sit over winter months. The issue is when I turn the key to the on position my ASD relay along with the trans relay in the PDC tick very fast and loud. The ticking is accompanied by all my dash lights flickering to the same speed the relays are ticking. The truck starts and shuts down with the key, just won’t go into drive or reverse. Everything worked great when parked. Thanks in advance for any info\advice. Also this is my first post so not sure if I put it in the correct place. Be nice and steer me in the right direction if I posted incorrectly!
  • Replies 3
  • Views 988
I would think relay not staying on would mean bad connection, possibly fuse. Look for sings of mice chewing on wires maybe. Could be lose ground terminal or battery.
I don't have a diagram for a '97' but in a '99' those relays and the transmission are controlled by the Powertrain Control Module.  Check the ground wires for the Powertrain Control Module.  They are black with tan stripe at the C connector pins number 31 and 32.  They ground at the right side battery.  They go through a splice and a connector before grounding at the battery.
Edited by IBMobile
Did This Forum Post Help You?
Show the author some love by liking their post!
