Parking brake light wont come on
- Replies 3
- Views 1.8k
Haggar 1 post
Dieselfuture 1 post
Christolher 1 post
Popular Days
In theory the park brake indicator is illuminated from the park brake switch(yes ground confirmation). BUT it is also commanded from the ABS module and will set with a code from the ABS also. Solid
My truck has had dead pedal since i put it back together after putting new hot rod pump and timbo tps. It threw a p0500 code the other night and i was wanting to reset tps and my parking brake cable broke a few years ago and i never fixed it, so i put a new switch on and still no light. I think it works off ground and when u ground it i should turn light on correct? I had a problem with tach not working awhile back and had cluster worked on and now my high beam light does work all time now.
Im wondering if my cluster is messed up and i guess u have to have parking brake light on to reset tps?
And if i replace cluster with one out of yard my truck is a 01 can i put a cluster out of a 02 that will read all the codes where the 01 doesnt?
