hello ... for several days it gives me the p0222 code but it did not cause a fault that I felt driving, I did not use the truck for a week and yesterday when I started it it made like 8 injection cuts in a row and very strong and then the engine was turned off I just started it several times but he did the same and the throttle does not respond and the only code he gives is the P0222, I am very worried I don't know what it will be. thanks for your help. Orlando
  • Replies 3
  • Views 1.1k
  • What year truck and how are you checking for codes? Any other info on the truck would help. The VP trucks are different from year to to year.
Hello friends ... when I bought the truck, 7 years ago it came with this vp44 and it showed that it had been repaired, I now did the process for the P0222 code on both connectors again and in step # 6 I DON'T CONTINUE When testing on terminal # 1 and # 2 of the TPS connector, I also tried to start it with the TPS disconnected and the engine started the same, with a purr that lasts 5 seconds and the engine shuts down alone.
