  • Replies 8
  • Views 2.1k
a fitler wrench, yes it is messy, and the filter is on the passenger side front right next to the block in front of the tire.  Nearly the same spot as a 24v or 12v
I find that if the motor is cool to the touch it’s not very messy. The filters usually back drain about 1/3 of their oil by then.
I still put a grocery bag around it thou.
don't they have a provision in the frame to drain the filter?
around the 5 min mark.
There is a little drain, but I don't like using it.
I've never seen that steering setup thou. It looks OE, but not the same as my 18.
that what mine looks like after i got the "updated" parts form the dealership. was a direct bolt on. when my factory passenger side broke. it was a recall. both my 08 and now my 04 has it.
His knuckle is different too, it must be a DRW setup. The drag link attaches to the tie rod, but on my truck (and another one I just looked at in the parking lot) the drag link has its own attachment point on the knuckle.
Found this online..
Bilstein Dual Steering Damper Kit for 2014-2019 Ram 2500 and 2013 ...
Hmmm. Just looked at a DRW, same as mine.
No, been the same since ‘13.
I’ll bet it’s 2WD
Yep, no front diff.
