P0260
Code p0260 popped up today. Can’t find anything on it. Any help would be appreciated. My only symptom is surging at 35-45-55 mph. I’ve had that problem before which was just a loose battery connection but I’ve checked everything I could think of and all connections are okay.
  • Replies 7
  • Views 1.4k
Went and checked again. I must have just remembered wrong. I had two codes, one showed up with key trick and one with scanner tool. P0236 and p0460
Edited by ColoradoColt
1 hour ago, ColoradoColt said:
Injection Pump Fuel Metering Control B Intermittent (Cam/Rotor/Injector)
Read more at: https://www.obd-codes.com/p0260
Copyright OBD-Codes.com
That’s what I found on it. But I still don’t really understand it
belive you are looking at a 3rd gen or  newer code maybe.
the 460 is a fuel level sensor code and the 236 is a MAP sensor code.
11 minutes ago, ColoradoColt said:
Okay thanks
we do have a list of DTC's here in the articles section, under 2nd gen 24 valve. That where I looked them up.
