Turbo upgrade
I need some advice for a new turbo. I’ve been looking at the ATS aurora or fleece cheetah. I wanna keep my exhaust brake.
Anyone how they either of them work with bigger injectors? I don’t pull to often when do it’s only a 9k camper. Mainly a daily driver.
2013 2500 longhorn
45% over s&s injectors
mm3 tunes by Coffman customs
  • Replies 6
  • Views 2.7k
Hmmm... What kind of EGT's to do you seen towing your RV?
You might look at tuning a bit more for seperate tune for RV towing if you don't already.
Might talk to @AH64ID he's our CR engine guru.
Trucks been sitting for a couple months but I wanna say some where around 800-900. I do have towing tunes. My stock turbo has oil in it and I wanna replace it before it runs away.
I don’t see a 13+ turbo from ATS. I’ve also heard some pretty bad things about their customer service.
If you’re only running 800-900° while towing, assuming pre-turbo, you’re getting plenty of air. A mild fleece might be the best choice, but I wouldn’t go too much bigger than stock our you’ll lose some towing and low end spool.
Have you asked Gecovey? Since he wrote your tunes I’d see what he thinks too.
https://www.atsdiesel.com/ats2/productdetail.asp?p=2023022392 Is the ATS turbo but haven’t seen very many reviews on it.
I’ll give a call tomorrow.
