Rough idle after new injectors
- Replies 7
- Views 4.8k
dripley 4 posts
gringocummins 2 posts
Mopar1973Man 1 post
Hi I have a 99 dodge 2500 with 62/68/14, 165 fass, bd exhuast manifold, bank high ram intake horn, edge juice, etc. I just got some 200 hp injectors that I put in to replace the stock ones. I fired up the truck after bleeding the fuel lines and it has a really slight lope/rough idle. This disappears under acceleration and only seems to happen at idle, when I look under the truck it appears that I have a small drip of fuel coming from the back of the block. Feeling the injector tube/fuel line connections they appear to be dry.. I'm a little at a loss as to what's going on
