- Replies 4
- Views 8.1k
Unreal Summit 2 posts
Mopar1973Man 1 post
IBMobile 1 post
Popular Days
Hold down 89in-lb High pressure fuel line fittings at injectors 28ft-lb High pressure fuel line fitting at pump 18ft-lb
I was kinda thinking that! Thank you for letting me know! I think I'll just just try a little a first if I have to crank on it then I will just tourqe it.
Can some one give me the torque spec for the vp44 side? I think it's 28ft pounds on the injector side and 89 inch pounds for the injector hold down. Crows foot pretty much mandatory for putting in new injectors and getting the right torque spec?
