- Replies 11
- Views 2.6k
randy4140 5 posts
JOHNFAK 3 posts
gassernomore 1 post
white01 1 post
Hey all, I have a 2000 CTD 2WD.I returned from a canoeing trip yesterday with no issues thru the trip at all, turned around in my drive and tried to back up to the garage and the truck wouldn't back up....The trans was like stuck in drive. I put it in Neutral and it still crept forward. Put it in reverse and it backed up like the brakes were on.... any ideas?How do I know if the trans is a 46RH or a 47RH.Could it be possible for the TC lockup to be stuck on? just an idea.I drained the pan and pulled it, initial inspection shows no visible issues, some debris on the magnet, no shavings ectThe VIN # is IB7KC2363YJI78907 If that helps to I D the trans
