- Replies 11
- Views 3.2k
RPM 3 posts
Mopar1973Man 2 posts
KOYOTE 1 post
JacksonDog 1 post
So, I have posted my problem on another forum and I am not getting much response. A couple of weeks ago my fuel pressure began to fluctuate. What happens is that the pressure is fine (19 psi) when I start the truck but it will soon drop to below five PSI. It will return to normal after to sits a while, but the pressure will always fall again. When the pressure begins to fall my Raptor pump begins to whine until it is very noticeable as the pressure approaches five psi and I shut the truck down. I changed the filter twice, checked my lines, changed the overflow valve twice and I still have the same problem. The only thing I can think of is that the Raptor is bad. It has only been on the truck since last June. I do not know if a tear in the diaphragm on the VP would cause this issue. Maybe I am missing something. I have attempted to contact Pureflow several times via email and voice mail (My problem is I work nights and I get off well before they open and I get up after they close) and have yet to hear from them about the pump or warranty. If the pump is done, I would think Pureflow would warranty it or at least tell my it doesn't qualify for warranty. If I have to buy a new pump then that is what I have to do I guess but I don't know if I will buy another Pureflow product due to the lack of customer service that I have received. I suppose my post rant questions are has anyone had this problem with Pureflow other than me? Is there something that I am missing with my pressure problem ? Thanks
