- Replies 5
- Views 4.3k
Mopar1973Man 2 posts
Me78569 2 posts
jag 1 post
Buddy has a 2004 - 2500 Cummins that will not make more than 28 lbs. boost. Tried plugging the wastegate (turbo is a 64 - 68 - 14) tried 2 different boost foolers, & a 20 lb. pressure test for boost leaks. Still won't go past 28. The only thing that I can find is the his MAF sensor is just plugged in & hanging there. There is no air box. Also there are no codes. We checked the MAP sensor & it is clean & not setting any codes. He says it made more boost even with it not installed before. Any ideas what else it might be? It also has a old BD fueling box with 3 settings & they don't even make a difference. Fuel mileage is way down to.
He is getting tired of being waxed by 4 cylinders!
