Egt probe install mess up
- Replies 5
- Views 2.2k
NIsaacs 2 posts
Tractorman 1 post
Irie808 1 post
ColoradoColt 1 post
Popular Days
I think Isspro will have the larger adapter fitting. You would need to drill it out and tap the next size, 1/4" if yours is 1/8". I doubt a pipe plug will seal either so that is out. If it would, you
So I installed a egt sensor when I got my adrenaline however long ago it was. Alls been fine up until last week. I noticed it was defueling very often with lots of throttle and I was hitting my 1200 egt limit very fast. I checked the fittings and the one that goes directly into the manifold is loose and I can hear a whistle. I’m worried to go any tighter because it would be at the very top of the threads and I’m worried it would make it too big to even hold the fitting at that point. Is there any other type of fitting I can use that’s a size up but will still fit the adrenaline egt probe?
Edited by ColoradoColt
