- Replies 3
- Views 2.6k
Mopar1973Man 2 posts
That Guy 1 post
Well I finally got it. I've tested this tune and really surprised you can hold the turbo at ZERO boost even at 65 to 70 MPH. After 150 miles in bit over a 1/8 of tank used. This includes climbing two 7% grades. Really cool to see the boost hang at zero but put it against a grade it barely 5 to 10 PSI boost. EGTs are bit higher climbing so I would not suggest towing or racing with this tune. What makes this tune so neat is the 5 to 14 PSI is flat stock tune 100% no boosted fuel on CANBus. At 15 PSI up it gains at a +5 step so it gains power quickly. Now if you toss in wiretap you better be ready... It pulls extremely strong in the upper boost range. Return to cruise state it hover about 19.5° BTDC at 2k RPM at ZERO boost. So this tune you can have your cake and eat it too...
I'll release this tune in the morning...
