Looking for Staff Members
Somone correct me if I am wrong!If my truck is running, and I supply power to the coil of my lift pump relay!Now I turn off the ignition will the engine stay running until I remove power from the lift pump relay?If nothing else stops the engine then that will allow it to run?
  • Replies 8
  • Views 2.2k
I think the engine gets killed by dumping power to the VP (turning the key off). The lift pump can stay running but it won't do anything but shoot fuel through the return line.
use the term "shoot fuel" loosely...as mopar1973man's video shows...it won't move much fuel...
http-~~-//www.youtube.com/watch?v=YREpPrMxkHU
you can actually see that the VP44 returns more fuel at higher rpms!
Well I was under the assumption that the lift pump was all that kept the engine running.So what else is controlled by a timer to let a turbo cool down.I want to make my own cool down timer for my truck.
I know, I'm the one that threatened him so he would make the video :lmao:
Well I was under the assumption that the lift pump was all that kept the engine running. So what else is controlled by a timer to let a turbo cool down. I want to make my own cool down timer for my truck.
Actually the feed to the Key ON wire from the ignition switch is held ON by the timer till the timer expires then the power is dropped. So this keeps everything in your truck operational PCM, ECM, lift pump, alternator etc. Also for security reasons the brake/trans selecter is usually monitored so if some see the vehicle run and figures he can drive off as soon as they it the brakes the engine dies. (Edge Juice - Turbo timer)
