Spongy brakes and Brake and ABS lights on
- Replies 10
- Views 2.6k
Mopar1973Man 5 posts
Tbird9140 4 posts
IBMobile 1 post
( 2000 Ram 1 tn 4wd diesel auto, 340000 miles) Now that I got my fuel pressure issue solved, my brakes have decided to act up. They have been "spongy" and not strong stoppers for about 200 miles. I was going to wait till I got home to address the problem. Now however the Brake and ABS dash lights have come on permanently when driving. I also do not hear the semi loud "boom" I always heard in the past when turning the key on. I am aware of the sensor on the rear differential, but is this the kind of symptom that a failed sensor would cause? Also is there not a 6 pin brake switch somewhere that occasionally fails. Any help or thoughts would be appreciated. Booster, master cylinder, wheel cylinders, etc. ????
