Twisted Brake Hose Situation
- Replies 12
- Views 2.7k
Andyba20 5 posts
Mopar1973Man 2 posts
IBMobile 2 posts
Sycostang67 1 post
Just a follow up on this. I had both hoses replaced. Also, I had been trying to fix what I thought was clutch chatter from my LS rear end, but the crimped/twisted hose was the culprit. Nearly identica
Someone did not install the caliper correctly. They twisted the hose before the install of the caliper. Most likely you need to replace both hoses now because the twist most likely damaged the hose.
I like the Raybestos or Centric brand products. Did they offer fries with that brake check?
This is my passenger side brake hose. I guess my question is, a.) anybody had this happen? Did I hit something? On full lock it’s rubbing a metal line. B.) what would you recommend I replace with?
