- Replies 10
- Views 1k
Mopar1973Man 4 posts
beautifulisblue 3 posts
Max Tune 2 posts
Silverwolf2691 1 post
Has to be either a loose/weak supply or ground. Time to trace, test and verify connection of wires involved. Intermittent electrical problems are the worst. You could fix the problem by just checking
There is a two wire plug on the socket just a PITA to remove so you can check. But you should be able to somewhat reach it from the driver side. I removed mine and installed 3A USB charger. One plug i
Exactly what I did. Ditched the stock head unit. Installed a Kenwood Bluetooth stereo. Then upgraded the cig plug to USB. The part I don't like is the Bluetooth to FM seems the volume is
Hey folks the lower power port in my truck works well, however, the cigarette lighter (upper). Will often take 10 seconds or so to power an accessory like a USB charger, and sometimes will go out for a minute.
Any thoughts on theories on low/ intermittent power from the cigarette lighter?
