Need to add 2nd battery back..
- Replies 12
- Views 1.9k
Max Tune 5 posts
Mopar1973Man 3 posts
YeaImDylan 3 posts
Silverwolf2691 1 post
Popular Days
There is a wiring diagram in the article section. I can take a picture of under my hood if you'd like. I bought this for my cable... https://www.ebay.com/itm/2-0-AWG-WELDING-CABLE-WIR
Then there are some of us still got our factory battery terminals, no corrosion, and in good condition yet. Tell you the trick keep all exposed metals coated with engine oil. This includes battery hol
Yep, learned the oil trick here, along with everything else I know about my truck....👍👍👍 My cable ends were really bad. When I cut them off the cable itself looked black, so I decided to change i
Hey all. So, truck runs on one battery due to previous owner making their own compounds in the garage and putting them in and deleting the battery. I'm wanting to get 2 fresh batteries and do everything back the right way (and sadly may buy all new cables for 300
). I'm wandering if anyone has a diagram that will show every ground and wire I need coming off the passenger side battery? Also, is there some sort of isolator or something that may be removed? If not removed but disconnected, where would it be? Any suggestions are appreciated so I can get this done correctly! Haven't had issues starting her in 25 * with no grid heater or plug but I want the truck done right and also maybe fix electrical issues she may have due to changing grounds around...
Thank you!
Dylan
