2001 2500 Fan Pulley bolts
Anyone have or know where I can find the 6 fan pulley bolts for an 01 2nd gen.  My son's fan hub bearing froze and sheared all the bolts of the fan pulley.  I've tried MoparPartsGiant and they are stating there is an 80 day wait!....really need them much sooner.  Even if I knew length, thread/pitch then I could go from there...
Thanks,
Bruce
  • Replies 4
  • Views 5k
Can you get one out of the fan hub for a pattern
Rockauto lists the thread as 5/16-18 if that is correct it's 5/16th UNC, as for length measure depth of hole in hub, add fan and washer thickness and subtract some so as bolts aren't bottoming out.
As for grade, 8.8 minimum, 10.9 is what I would use
https://www.rockauto.com/en/moreinfo.php?pk=815215&cc=1366602&pt=6812&jsn=455             doesn't list the bolts but shows the size on the specs of the hub
Me I'd get 5/16th UNC say 1 3/4" long 10.9 grade with spring washers and cut to length making sure after cutting to length they all screw into the hub by hand, also don't get bolts get set screws, set screws do not have a shoulder bolts do (at least they do here in the UK)
Google Fu says M6 x 1.0 x 10mm long.. Found for a first gen Cummins though. Common rails are 14mm long, same thread pitch.
@wil440, he wants the 6 that go into the bearing hub bracket that attaches the pulley to the block.
Thanks Guys! and yes Silverwolf, they are the 6 that attach the pulley to the bearing hub.
BDK
BDK
DOH.... sorry wrong bolts
I should have spotted " 6 "
