ABS and Brake light issue
- Replies 7
- Views 1.8k
Popular Days
also make sure you check the junction plug behind the drivers front wheel well cover. It can get covered in road debris and lead to a bad connection of all wiring going to the back of the truck.
hey guys and gals:
Currently having an issue with my ABS/Brake light popping on then staying on- doesnt happen 100% of the time but a majority of driving time they are both on!
I have replaced the rear axle speed sensor as well as the transmission sensor. The speedo needle will bounce very erratically and the brake pedal will sometime fall while sitting at a stop.
I am thinking i have a booster problem or a proportioning valve issue. the left front tire will sometimes lock up hard under medium brake application. All the brakes lock up fairly easily on wet roads though.
I have done full brake jobs with new wheel cylinders in the rear and new calipers on the front along with new flex lines on the front as well.
Any ideas or thoughts or "I've had that happen and this was the fix"
Thanks for your time on this.
