So I bought the Quadzilla with Iquad and I been holding off installing it because I have a lot of lopping and to me too much black smoke with the 50 hp new bosh bodies. Dont know if the surging is due to this or not, I plan on sending them back to get them checked to see if theres a problem going on with them. In the mean time I though I would buy new crossover tubes just to have a piece of mind that they are good to go. Question is what injectors would you suggest to run for fuel mileage and towing with the Quadzilla?
  • Replies 2
  • Views 972
You know my set up. +50HP injectors should be easy to build a tune for and reduce the smoke.
As for loping I would check valve lash, also too much timing down too low in RPM can produce bucking.
I did set valves at 8 and 18, I read I think a post you made about that. I just hate ticking valves.
